NI TestStand
webserver too slow
Hi.
I´ve a problem with the Webserver.I used the Web Publishing Tool to create a html file View Mode Embedded.
My VI read data from RS-232 port every 2 seconds. The problem is: When the HOST has control of the VI, the webpage in the CLIENT does not refresh every 2 seconds like the HOST's screen, and sometimes the connection is broken.
BUT if the CLIENT takes control of the VI, CLIENT and HOST are updated every 2 seconds and the connection is never broken.
Then I used 2 diferents PC to try this behavior.
I'm using LV 8.2     Win XP
Is it a normal behavior ?
How can I solve it?
Is there other way to do a web publishing?
Raymundo Cassani
(3,220 Views)
This doesn't seem like a TestStand problem, maybe you should re-post to the labVIEW forum
Regards
Ray Farmer
Regards
Ray Farmer
(3,195 Views)
OK.
Thank you
Raymundo Cassani
(3,185 Views)
