which veriable hold the sequenceFile Version?
HI,
The SequenceFile Properties has a version field.  When can I find it in the RunState variables?
Rafi
(3,867 Views)
Hi Rafi,
Yes you can find it there. You have just to use the parent class of SequenceFile, the propertyObjectFile
Just take a look at the example
Greetings
Juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
(3,857 Views)
Hi Juergen,
I'm using TS3.5 and I can't run your seq.  You must be running on TS4.0.
Can you save it as a TS3.5?
Rafi
(3,849 Views)
Hi Rafi,
The TS3.5
juergen
--Signature--
(3,845 Views)
Dear juergen
The sequence gives an error
Error , An error occurred evaluating the Title Expression:
Unknown function or sequence name 'RunState.SequenceFile.AsPropertyObjectFile'.
[Error Code: -17320, Unknown function or sequence name.]
If you look at the context (on a breakpoint..), you don't see this variable.
Any idea?
Rafi
(3,809 Views)
Hi Rafi,
Thats clear !?! You are using TS3.5 and this does not support api calls
you have to use ActiveX.
I will provide a example soon as possible!
Greetings
Juergen
--Signature--
(3,807 Views)
Hi Rafi,
Check this out. I tried it under TS4.1
Let me now if it works
Greetings
Juergen
--Signature--
(3,805 Views)
