NI TestStand
why "specify module","edit code" options is disable?
With a Custom Step Step there should not be any Specify Module because the code will be on a PostSubStep. Therefore you disable the Specify Module, Edit Code etc to stop users changing the functionality of the Custom Step Type by adding a Code Module to it.
Regards
Ray Farmer
Message 11 of 16
(1,517 Views)
hi Sathish
  thank you for your reply.i tried what you mention above, it worked, thank you! do you have any documents for how to build custom step types? would you like to send me a copy if you have? my e-mail is :vimingchan@gmail.com .
thank you
viming
Message 12 of 16
(1,510 Views)
hi  dowNow:
  yes, you are right. i just want to study the code and see how it run.
thank you
viming
Message 13 of 16
(1,509 Views)
you can try this for starter
http://zone.ni.com/devzone/cda/tut/p/id/8300
Regards
Ray Farmer
Message 14 of 16
(1,504 Views)
Hey viming,
This should also help you.http://zone.ni.com/devzone/cda/tut/p/id/2772
BTW there is a TestStand 2 customization manual that should have a step by step process.
Sathish
Message 15 of 16
(1,500 Views)
dear all:
  thank you very much for all your help!
viming
Message 16 of 16
(1,483 Views)
