NI VeriStand Add-Ons Discussions
Chassis TimeSync Custom Device Feedback
And this is the screenshot of what I see in max for the time sync options
Message 71 of 115
(6,735 Views)
THe problem is you do not have NI-TimeSync 1.2 installed on the real time target. you have 1.3. You must use 1.2
Stephen B
Message 72 of 115
(6,735 Views)
No I am not using 1.3, I sent the wrong screenshot of the local software where I have both versions but attached is off the PXI and on the PXI I have 1.2 installed.
Message 73 of 115
(6,735 Views)
I am really frustrated with these garbage sync cards now
Message 74 of 115
(6,735 Views)
Hi Usman,
I'm sorry to hear that. I think a lot of the frustration is with going back and forth with me on changing configuration settings. Keep in mind everything you need and everything I have said is documented on the instructions. I realize they are long but I feel this would have saved you a lot of time and frustration:
https://decibel.ni.com/content/docs/DOC-29546#Installing_the_Chassis_TimeSync_Custom_Device
http://www.ni.com/white-paper/14637/en#9.EtherCATSinglePointwithXNETTimeMultipleControllersMultipleC...
After these past few pages of discussion, we have accomplished everything those documents state now... so reviewing them now won't accomplish anything. So... moving forward... can you please tell me if you see "timesync: ni-sync now active" somewhere in the console on the targets?
Stephen B
Message 75 of 115
(6,735 Views)
I will try 1 more time doing everything all over again and see it works or not...
Message 76 of 115
(6,735 Views)
Before you do that, can you please check the console for that message?
Stephen B
Message 77 of 115
(6,735 Views)
I do not see that... here is what I see
System Definition Details
Version: 1.0.0.206
Description:
Loaded 0 calibrations.
Initializing DAQ devices...
Initializing DAQ waveform tasks...
Initializing engine timing sources...
Timing source VI ran
Initializing FPGA devices...
Initializing inline custom devices...
ni.var.io://localhost/EtherCAT Master/Device/Mod1 - Slot: 1 - Model: 9401
ni.var.io://localhost/EtherCAT Master/Device/Mod2 - Slot: 2 - Model: 9239
ni.var.io://localhost/EtherCAT Master/Device/Mod3 - Slot: 3 - Model: 9265
ni.var.io://localhost/EtherCAT Master/Device/Mod4 - Slot: 4 - Model: 9401
PCL synced
Scan Engine Period: (uSec): 1000
Initializing data sharing devices...
Initializing models...
Synchronizing Timed Structures:
Controller2_HP
Controller2_LP
Controller2WatchdogLoop
Synchronization Timeout: 120000 ms
Starting asynchronous custom device loops...
Chassis TimeSync sample clock generation completed.
Starting model execution loops...
Starting DAQ DIO loops...
Starting DAQ waveform task loops...
Initializing Primary Control Loop...
Running system definition...
Target: Controller2
System definition: TimeSyncWith6683H
Version: 1.0.0.206
Description:
Creator:
Start time: 08:49:29
11/08/2013
Starting Inline Custom Devices...
Primary Control Loop initialization complete.
Data Processing Loop started...
Primary Control Loop started...
Message 78 of 115
(6,735 Views)
If you dont see that anywhere in the console log ... that is the problem.
The portion you posted is only after the sysdef was deployed. I'm expected to see it anywhere... even right after boot. Can you copy paste the whole console log so we can look through it?
This is what timesync 1.2 plugin for ni sync does
To verify timesync 1.2 is installed properly can you navigate on the target to /ni-rt/system/ni-timesync/
Does that folder exist? If so, can you look for ni-timesync-nisync.ini in there? If so, can you copy paste the contents of that ini file here?
Thanks for your patience
Stephen B
Message 79 of 115
(6,735 Views)
I rebooted the PXI and I get this. Attached is the screenshot and it does say that sentence
Message 80 of 115
(6,735 Views)
