04-22-2014 09:33 AM
I added the 'Initialize Veristand' step first. Yes, this happens with any sysdef, including the Sinewave Delay example project.
Kevin_F wrote:
Hmm, Did you drop and configure the initialize veristand step first?
Is it with any system definition or just a specific one - I just tried with a test one and that step seems to work OK.
04-22-2014 10:21 AM
Ok, I found the problem. Something changed between 2012 and 2013 that I didn't anticipate. I'll post a fixed version soon.
04-22-2014 10:37 AM
New version is published,
The model parameter dialog now lets you select any channel which isn't ideal but my filtering for just model channels broke in 2013 so this is a temporary fix until I find a better way to filter the tree.
04-22-2014 11:03 AM
With that fix, I can configure a model parameter value. I was using a parameter initialization file in VeriStand perviously. Using the same parameter and value with the 'set model parameter value' custom step type, I get an error as shown in the attached photo.
04-22-2014 03:09 PM
I am also getting this exception when trying to open and deploy an RT sequence...
The message indicates a syntax error, but it compiled in the stimulus profile editor.
04-22-2014 03:20 PM
Can you post the RT sequence you are using/the configuration of the step?
I think the parameter stuff is probably another bug, I'll see if I can figure out whats going on
04-22-2014 03:55 PM
Well I see the bug, if model name doesn't match the model expression then it won't work right now. I just uploaded a fixed version. Let me know if that works for you.
04-23-2014 06:59 AM
It worked, thanks. It didn't work initially with my existing sequence. I had to delete my existing 'set model parameter value' steps and create new ones in order for it to work, but it is fine now.
04-23-2014 08:20 AM
Maybe I just don't understand how to use the 'open and deploy RT sequence' custom step. I have an existing RT sequence that I want to initiate via TestStand. Is this the correct step type? Sometimes TestStand gets locked up when I try to configure this step type. I give it time to complete, but it never does. Sometimes I get an exception when configuring the step type.
04-23-2014 08:29 AM
I also am not exactly sure what I am supposed to be configuring in the dialog? I already configured the variables in the sequence file. What is supposed to go in the 'parameter value' field?
