NI VeriStand Add-Ons Discussions
Custom VeriStand Steps for TestStand Feedback
Kevin,
It works now.  The Get Sequence Name step was adding a ":1" to the end of my file name.  However, now it still won't actually run the RT sequence.  It just jumps into the while loop and loops forever until I terminate it.
Message 111 of 202
(1,562 Views)
Hmm,
If you open up the workspace while it is running can you tell if the sequence being applied? I just wonder if the problem is in running the sequence or in reading the state.
Kevin Fort
Principal Software Engineer
NI
Message 112 of 202
(1,562 Views)
Kevin,
It does not run on the workspace.  When I run the RT sequence from the stimulus profile editor in VS it works just fine, but when I try and call that same RT sequence through TS it doesn't actually run the sequence.
Message 113 of 202
(1,562 Views)
Kevin,
I fixed the problem.  I found out that in order for the sequence to run, when you set up the parameters in the Open and Deploy step, you have to set up the parameters as Paths, and the value as their path in the VS project.
Message 114 of 202
(1,562 Views)
Ah ya, Glad you got it working
Kevin Fort
NI
Message 115 of 202
(1,562 Views)
Using 2013 & the v300 Add-on.  I get an exception when selecting my sysdef in the dialog for the 'set model parameter value' custom step type.
Message 116 of 202
(1,562 Views)
Hey dafdi13,
What exception do you get?
Kevin Fort
NI
Message 117 of 202
(1,562 Views)
************** Exception Text **************
System.NullReferenceException: Object reference not set to an instance of an object.
   at NationalInstruments.VeriStand.SystemStorage.TravNdCompoundFilter.CheckWithFilter(BaseNodeType node)
   at NationalInstruments.VeriStand.SystemStorage.FilteredHierarchyRetriever.InsertSortedChildren(List`1 unfilteredDirectChild, BaseNodeType parent)
   at NationalInstruments.VeriStand.SystemStorage.FilteredHierarchyRetriever.Visit(SectionType element)
   at NationalInstruments.VeriStand.SystemStorage.SectionType.Accept(IVisitorWithInspection visitorInspection)
   at NationalInstruments.VeriStand.SystemStorage.BaseNodeType.GetSortedNodeChildren(Boolean deep, Boolean naturalSort, String[] guidsToSkipChildSort, ITraverseNodeFilter filter)
   at NationalInstruments.VeriStand.SystemStorageUI.SystemDefinitionBrowser.PopulateOnlyChildrenWithValidItem(TreeViewItem parentItem)
   at NationalInstruments.VeriStand.SystemStorageUI.SystemDefinitionBrowser.InitializeNewTreeViewItem(BaseNodeType node)
   at NationalInstruments.VeriStand.SystemStorageUI.SystemDefinitionBrowser.set_StartNode(BaseNodeType value)
   at NationalInstruments.VeriStand.SystemStorageUI.StorageChannelAndAliasBrowser.RepopulateBrowser()
   at NationalInstruments.VeriStand.SystemStorageUI.StorageChannelAndAliasBrowser.SetSystemDefinitionDisplayFilter(ISystemDefinitionBrowserFilterType channelViewFilterType, ITraverseNodeFilter channelViewCustomFilter, ISystemDefinitionBrowserFilterType aliasViewFilterType, ITraverseNodeFilter aliasViewCustomFilter)
   at NationalInstruments.VeriStand.SystemStorageUI.WinFormsWrapper.TreeAliasBrowserWF.set_DisplayFilter(ISystemDefinitionBrowserFilterType value)
   at OpenWorkspaceDialog.NativeChannelSelectionDialog.InitializeListBox(String _sysDefPath)
   at OpenWorkspaceDialog.NativeChannelSelectionDialog.openFileDialog1_FileOk(Object sender, CancelEventArgs e)
   at System.Windows.Forms.FileDialog.OnFileOk(CancelEventArgs e)
   at System.Windows.Forms.FileDialog.HandleVistaFileOk(IFileDialog dialog)
************** Loaded Assemblies **************
mscorlib
    Assembly Version: 4.0.0.0
    Win32 Version: 4.0.30319.17929 built by: FX45RTMREL
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
zNationalInstruments.TestStand.DotNetAdapterGAC
    Assembly Version: 5.1.0.226
    Win32 Version: 5.1.0.226
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_32/zNationalInstruments.TestStand.DotNetAdapterGAC/v4.0_5.1.0.226__ad9244eb3b825cd8/zNationalInstruments.TestStand.DotNetAdapterGAC.dll
NationalInstruments.Veristand.VeristandSteps
    Assembly Version: 1.0.0.1
    Win32 Version: 1.0.0.1
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_32/NationalInstruments.Veristand.VeristandSteps/v4.0_1.0.0.1__25624132ff430a06/NationalInstruments.Veristand.VeristandSteps.dll
System
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
NationalInstruments.VeriStand.ClientAPI
    Assembly Version: 2013.0.0.0
    Win32 Version: 2013.0.0.71
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/NationalInstruments.VeriStand.ClientAPI/v4.0_2013.0.0.0__a6d690c380daa308/NationalInstruments.VeriStand.ClientAPI.dll
DotNetAdapterManagedSupport
    CodeBase: file:///C:/Program%20Files%20(x86)/National%20Instruments/TestStand%202013/Bin/DotNetAdapterManagedSupport.DLL
System.Core
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
NationalInstruments.TestStand.Interop.UI.AxControls
    Assembly Version: 5.0.0.252
    Win32 Version: 5.0.0.252
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/NationalInstruments.TestStand.Interop.UI.AxControls/5.0.0.252__ad9244eb3b825cd8/NationalInstruments.TestStand.Interop.UI.AxControls.dll
NationalInstruments.TestStand.Interop.API
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/NationalInstruments.TestStand.Interop.API/5.0.0.252__ad9244eb3b825cd8/NationalInstruments.TestStand.Interop.API.dll
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/NationalInstruments.TestStand.Interop.UI/5.0.0.252__ad9244eb3b825cd8/NationalInstruments.TestStand.Interop.UI.dll
Microsoft.CSharp
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Microsoft.CSharp/v4.0_4.0.0.0__b03f5f7f11d50a3a/Microsoft.CSharp.dll
Accessibility
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
NationalInstruments.TestStand.Interop.UI.Support
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/NationalInstruments.TestStand.Interop.UI.Support/5.0.0.252__ad9244eb3b825cd8/NationalInstruments.TestStand.Interop.UI.Support.dll
System.Dynamic
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Dynamic/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Dynamic.dll
Anonymously Hosted DynamicMethods Assembly
    Assembly Version: 0.0.0.0
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_32/mscorlib/v4.0_4.0.0.0__b77a5c561934e089/mscorlib.dll
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/NationalInstruments.VeriStand.SystemStorageUI/v4.0_2013.0.0.0__a6d690c380daa308/NationalInstruments.VeriStand.SystemStorageUI.dll
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/NationalInstruments.VeriStand.SystemStorage/v4.0_2013.0.0.0__a6d690c380daa308/NationalInstruments.VeriStand.SystemStorage.dll
PresentationFramework
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.dll
WindowsBase
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/WindowsBase/v4.0_4.0.0.0__31bf3856ad364e35/WindowsBase.dll
PresentationCore
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_32/PresentationCore/v4.0_4.0.0.0__31bf3856ad364e35/PresentationCore.dll
System.Xaml
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xaml/v4.0_4.0.0.0__b77a5c561934e089/System.Xaml.dll
WindowsFormsIntegration
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/WindowsFormsIntegration/v4.0_4.0.0.0__31bf3856ad364e35/WindowsFormsIntegration.dll
UIAutomationTypes
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/UIAutomationTypes/v4.0_4.0.0.0__31bf3856ad364e35/UIAutomationTypes.dll
UIAutomationProvider
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/UIAutomationProvider/v4.0_4.0.0.0__31bf3856ad364e35/UIAutomationProvider.dll
PresentationFramework.Aero
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework.Aero/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.Aero.dll
NationalInstruments.VeriStand.Internal
    Win32 Version: 2013.0.2.3
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/NationalInstruments.VeriStand.Internal/v4.0_2013.0.0.0__a6d690c380daa308/NationalInstruments.VeriStand.Internal.dll
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/NationalInstruments.VeriStand/v4.0_2013.0.0.0__a6d690c380daa308/NationalInstruments.VeriStand.dll
NationalInstruments.VeriStand.SystemDefinitionAPI
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/NationalInstruments.VeriStand.SystemDefinitionAPI/v4.0_2013.0.0.0__a6d690c380daa308/NationalInstruments.VeriStand.SystemDefinitionAPI.dll
System.Xml
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
System.Configuration
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
Microsoft.GeneratedCode
    Assembly Version: 1.0.0.0
NationalInstruments.VeriStand.XMLReader
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/NationalInstruments.VeriStand.XMLReader/v4.0_2013.0.0.0__a6d690c380daa308/NationalInstruments.VeriStand.XMLReader.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
    <system.windows.forms jitDebugging="true" />
</configuration>
Message 118 of 202
(1,562 Views)
Hmm, Did you drop and configure the initialize veristand step first?
Is it with any system definition or just a specific one - I just tried with a test one and that step seems to work OK.
Kevin Fort
NI
Message 119 of 202
(1,562 Views)
I read this in the documentation:
To change model parameter or model execution state first execute the Open Model Manager Step
-Model parameters can be updated individually using the Set Model Parameter Value Step or from file using the Update Model Parameters from file step
-Models can be stopped and started using the Set Model Execution State Step
I don't see the 'open model manager step' or the 'set model excecution state step'
Message 120 of 202
(1,562 Views)
