NI VeriStand Add-Ons Discussions
Embedded data logger- add timestamp and comments
I want to add timestamp for all logged data and some string commens which are read from .ini file into the TDMS file that generated by embedded data logger add-on. Is the source code of embedded data logger available for us? or any other good suggestion?
(4,279 Views)
For the timestamp, the easier way is to add the "Absolute Time" in the recorded channels list.
For the comments, you could add them when you upload the record file from the target.
Regards
(3,942 Views)
