NI VeriStand Add-Ons Discussions
FXP_LLB Broken VIs
I am in the process of upgrading my modified SE-ECAT custom device from LV2011 to LV2015, the modification does not include changes to the FXP_LLB project. The mass compile process of the FXP_LLB project returned a list of Bad VIs. All the 128 "Scanned Variable Read (FXP) - X bit - ..." VIs are broken. However, when checking my functional LV2011 FXP_LLB project these VIs are also broken. Is this normal or have is there changes I need to make to both versions?
(3,911 Views)
You shouldn't have broken vis. The source code is available on github, so you should start from there.
There is also compiled version for 2015 at https://decibel.ni.com/content/docs/DOC-15510
CLA, CTA
(3,480 Views)
