NI VeriStand Add-Ons Discussions
Engine Simulation Custom Device Feedback
Can you post your system definition file please
Stephen B
Message 221 of 247
(1,422 Views)
Here is the original I'm trying to load with the error above:
Message 222 of 247
(1,422 Views)
Nothing attached
Stephen B
Message 223 of 247
(1,422 Views)
forum doesn't let me attach until after I post a comment 😉 its there now  James
Message 224 of 247
(1,422 Views)
got it. to do attachments the first time click the 'use advanced editor' when you reply (in top right hand corner)
Stephen B
Message 225 of 247
(1,422 Views)
Hi James,
I dont see anything wrong with the sysdef. The error information you posted from the console is a screenshot and I think the important information is cut off. Can you highlight all the text (click, ctrl+A) and copy paste it into a text file.
Stephen B
Message 226 of 247
(1,422 Views)
adding txt file
Message 227 of 247
(1,422 Views)
OK so this is the real problem happening:
System error encountered.
:::Details:::
Error code: -89140
Error Message: Driver cannot complete the route, because the only way to make the
route requires a trigger bus line, and no trigger bus has been configured in MAX
for this device.
If you have a PXI chassis, make sure it has been properly identified in MAX. If y
ou are using a PCI device, create a RTSI cable in MAX that includes your PCI devi
ce even if you are not using any RTSI cables.
Property: SampClk.OutputTerm
Destination Device: PXI1Slot5
You need to go into MAX and find your RT target. Based upon the name of the card "PXI1Slot5" I assume it is a PXI chassis. However, I don't think you have identified the PXI chassis so NI VeriStand cannot make the appropriate signal routing. Our newer PXI Express chassis do this automatically, but older PXI chassis don't. Under the RT Target, expand devices and interfaces, and follow the instructions shown on #2 here: http://www.ni.com/white-paper/11136/en/
Stephen B
Message 228 of 247
(1,422 Views)
Hi Stephen,  Why would I need to do this? my PXI chassis has been working fine for 1.5 years.  MAX can see it ok : see attached.
Message 229 of 247
(1,422 Views)
I don't have an "identify as" option I have an "rename alias" option. should I give my alias a name? RIO0 ?  james
Message 230 of 247
(1,422 Views)
