05-02-2018 06:12 AM
Hi everyone, I don't know if somebody has some experience with this Instruments Add on If you have no experience any Idea would be anyway appreciated.
I'm using a PXIe System with an Ethernet Card PXIE 8231.
I have a Waveform Generator connected by LAN to the Ethernet Card, the Ethernet Card is connected to the Computer through the PXIe Chassis. I don't know if I should create some Channels and Messages in Custom Device from Veristand.
I also don't have any Idea of what to write in "Port"
Any Idea of what could be wrong?
09-15-2021 03:21 PM
I am currently seeing the same error with the "Engine Simmulation Toolkit" custom device.
Did you ever discover what was causing this error? If so, can you please share what worked for you?
Cheers!
