NI VideoMASTER and NI AudioMASTER
TestStand 2010 and AudioMASTER 6.2 compatible?
Are TestStand 2010 and AudioMASTER 6.2 compatible?  I know the AudioMASTER documentation states to use 4.2, 4.1, etc., but I think it was released prior to TS 2010.
(8,535 Views)
From my experience Audio and VideoMASTER are usually forward compatible.
You may want to post this question on their forum though.
CTA, CLA, MTFBWY
(8,532 Views)
Accepted by topic author TBone314
The AudioMASTER forum is very quiet, so I posted here...
I have experimented, and they appear to be working together.  AudioMASTER requires TestStand 4.2.1 (not TestStand 2010) to be installed prior to the AudioMASTER installation, so I installed both TestStand 2010 and TestStand 4.2.1.  I then had to manually copy the AudioMASTER TestStand components (icons, typepalettes, steptypes\mx_types) in \\users\documents\public documents\national instruments\teststand 4.2.1\components  to \\users\documents\public documents\national instruments\teststand 2010\components.  TestStand 2010 prompted me to update the types and .ini files when I opened and then closed TestStand 2010.
(8,525 Views)
