‎07-02-2013 12:59 PM
i got solution to my answer from other source...
but please rply other's queries...since i have same doubts...
‎07-03-2013 12:17 AM
Embedded Module for ARM is avilable for microcontroller programming.But it supports specific modules like EK-LM3S8962.
You have two options:
1. try to add LPC21489 ARM7TDMI board in Embedded Module. You may need ULINK2 USB-JTAG adaptor if you are using Keil µVision.
2. Interface board through serial port & pass data.Progamming of microcontroller can be done by supported compiler. You can develop your GUI in Labview.
‎07-03-2013 12:19 AM
Hi
Provide your hardware details.
For software DVD you can contact Application Engineer.
You can also download it from ni.com.
‎07-03-2013 12:21 AM
What king of hardware you are looking for.
contact ni.com or send details.
‎07-03-2013 12:22 AM
‎07-03-2013 12:26 AM
1. For hardware you can send details or contact ni.com
2.To use gerber file, you have to use NI ultiboard. Ultibaord is toatally differrent software & not part of Labview.
‎07-24-2013 11:21 AM
Hello Sir,
Pleasure to have you as our mentor.We are dveloping a project on Smart Security for Fisherman.We have finished the hardware design of our project and now for the lab view we are using VI software for which we need to process the output signal of GPS from dollars to Latitude and Longitude.Is it achievable using a DAQ chord?
Thank You.
