NIYANTRA Discussions
[Group N] NIYANTRA 2013:Ask Your Mentor
Sir,
     Can I use hardwares from third party(available in market other than NI) which can be compatible with labview to implement my project??
Message 11 of 23
(4,846 Views)
Hi Ganesha
You can use third party hardware which is compatible with LabVIEW. NI also loans hardware for Niyantra. You can look it up here. https://decibel.ni.com/content/docs/DOC-30191
Message 12 of 23
(4,846 Views)
Sir,
       Actually i wanted hardware other than those specified in the list. What do I do in this regard? Can I buy them from NI or outside? Also are all hardware's(NI or available outside) compatible with all versions of LABVIEW?
Thank you
Message 13 of 23
(4,846 Views)
You can use other hardware, but you might want to check if LabVIEW drivers for the hardware exist.
Message 14 of 23
(4,846 Views)
sir,
can we use 3rd party boards(psoc evaluation kit) to interface with sensors, and then pass the data to LABVIEW for processing?
Message 15 of 23
(4,846 Views)
sir,
          In video presentation i need to show the demo of my project or it is show a real time implementation?? because my project is about "Automatic fault locating and control in distribution system" so if i need to show demo of 1 phase faults or 3 phase real time faults?
Message 16 of 23
(4,846 Views)
Respected sir,
          I am doing Home automation with energy genetrification project. I need 4 analog inputs and 8 analog outputs. So i need to buy DAQ box. So kindly guide to buy me a correct DAQ box with low cost.
Message 17 of 23
(4,846 Views)
Sir
I am trying to interface can and iso 9141 protocol using my arduino board. So far i have not been able to do so.
Is there relevant ni product that supports it?
The sbRIO and usb 9234 boards seem to support them. Can you please confirm, for both the protocols.
Message 18 of 23
(4,846 Views)
How to develop android application using lab view????
And how to track mobile through GPS in lab view software???
Do you provide any hardware for GPS simulation???
Message 19 of 23
(4,845 Views)
Yes you can.
Message 20 of 23
(4,845 Views)
