PXI
3D Mechanical Models -PXIe-8431/6 PXI-8432/4 PXI-8433/4
I’m designing an electrical 3D Model of a system that uses Models PXIe-8431/6, PXI-8432/4 & PXI-8433/4
Do you have a 3D mechanical models of these parts that you can share?
(3,688 Views)
Hi IRL2016,
We (NI) provide some CAD or engineering drawings of products in the resources section of the particular item. However, if the drawings are not in the resources section, we cannot provide them to you. However, for the PXI modules you have mentioned, these all confrom to standard dimensions, which you should be able to attain. In this case only the connection may vary.
I hope this helps.
Nathan
(3,654 Views)
Thanks Nathan,
That is useful information. If you know of a specific or generic model from that family I'd appreciate it if you can post a link.
Regards
Paul
(3,651 Views)
Accepted by topic author IRL2016
I would try searching here:
http://www.ni.com/dimensional-drawings/
Nathan
(3,649 Views)
