PXI
PXIe-1085 slot type in chassis prom does not match
In developing an application, it is required to find out slot number of PXIe system timing slot. Based on spec, we programmed to get this data from prom of PXIe-1085 but failed to do so.
The system timing slot of 1085 is slot 10. The value of slottype of slot 10 in 1085 chassis prom should be 0x07. But, the actual value in 1085 chassis prom is 0x01.
Is there an update to patch 1085 chassis prom?
Message 1 of 1
(3,117 Views)
