PXI
784068-01 PXIE-413x
I'm trying to find the torque specs and wire stripping information for 784068-01. The kit comes with PXIE-413x connector. However each time I click on the user manual it opens 414x connectors specs. I need the user manual stating strip lengths for the screw terminals and the torque specs for all screws.
(221 Views)
I don't see a logical reason why 414x specs would vary from 413x, NI typically uses Phoenix's combicon connectors and standard screw terminals, assuming they used the same family of connectors, the electrical wiring requirements would match.
Santhosh
Soliton Technologies
(198 Views)
I see I didn't realize they are using the same screw terminals. It would explain why it opens for the 414X.
(179 Views)
