PXI
9237-Self Test in MAX
I am using a chassis 9073,having 3 cards out of which one is 9237.
9237 was used as half bridge,now changed to full bridge.I wanna calibrate it.
I have a docu for it from the internet.In that it is mentioned that,i have to self test.
The chassis alone is listed in the Max,how can i self test this card??
Pls help.
(3,884 Views)
Hi Krupa! You can self test your card in NI-MAX. Open NI-MAX, and then expand "My System" -> "Devices and Interfaces" and then select your card. You should find an option to self-test.
(3,876 Views)
That is only true if you are using cDAQ.  In this case krupa is using cRIO, which does not support Self-Test or Self-Calibration from MAX.  I'm not 100% sure, but I think you may have to do it programmatically.
http://zone.ni.com/reference/en-XX/help/370984T-01/criodevicehelp/converting_and_calibrating_analog_...
(3,870 Views)
