PXI
AIM ARINC board not detected with MXIe in a PXI-1033 chassis
I have a PXI-1033 chassis with NI PXI-6229 and AIM boards (ARINC 429 & AFDX) linked to a PC with MXIe.
Windows can't attribute enough ressources to this device (indicated in the devices manager) so I can't install drivers for my boards.
If I only put NI PXI-6229 in my chassis, all is OK.
If I only put AIM boards in my chassis, Windows doesn't boot.
I tried with a PXI-1036 chassis linked to my PC with MXI-4, all is running correctly (NI and AIM boards).
Is there anyone who detects a problem of compatibility between AIM boards and MXIe links, and what is the solution ?
Thanks for answers.
Matthieu
(4,462 Views)
Mmonterrat,
Problems like this are quite often caused by the computer's BIOS.  Is there a BIOS update for your PC, and have you tried a different computer?
Robert
(4,456 Views)
Robert,
thanks for your help.
I updated my bios but there is always the same problem. I also tried with 2 other PCs (the same model and another), but it's not better.
My PC is a DELL PRECISION 380. If Someone has the same and could try ...
Matthieu
(4,453 Views)
Please first look at : http://zone.ni.com/devzone/cda/tut/p/id/5022 to see the Desktop PC which have been tested with MXIe.
Pierre R...
Certified LabVIEW Developer
(4,439 Views)
Please verify that your AIM ARINC card supports MXIe. Due to material architecture some of them are not compatible with MXIe link. Please contact your AIM ARINC saler
Pierre R...
(4,423 Views)
I find a solution : I will replace my PXI-1033 MXIe chassis by PXI-1036 and MXI4 cards. I'm sure that it's OK.
Thanks to everybody.
(4,421 Views)
