PXI
Analog Input Range PXI-7831R
I have a question concerning the analog input range of the PXI-7831R card:
The datasheet states a range of +/-10V analog input range. Now, what's the result when I hook up +10.5V and read out the input?
Is it going to be able to give me +10.5V when I read it out or is it always limited to exactly +10.0V?
Chris
(3,021 Views)
Hello, The 7831R supports up to +/- 10V. If the voltage input is greater than +10 v or less than -10v you will read a constant value of +10 or -10.
(3,000 Views)
