09-30-2005 09:19 AM
10-03-2005 11:40 AM
Mudda,
Thank you for contacting National Instruments.
It looks like your configuration is correct, with the exception that you need to measure the voltage differentially instead of single-ended. Instead of using AISENSE, use AI Channel 0 (+) and AI Channel 8 (-) to do a differential measurement of the signal. This will prevent the possibility of a ground loop being introduced in your system, as well as remove common mode noise. Take a look at this (http://digital.ni.com/public.nsf/websearch/82508CD693197EA68625629700677B70?OpenDocument) KnowledgeBase article for more information about measuring current using the Analog Input of a DAQ board.
