I require a specific custom interface to a UUT using a proprietary high speed bus.
My kit is sitting in an NI chassis using LabView and TestStand.
Does anybody know of any commercially available PXI Breadboard cards available other than the ones produced by Pickering? (And as a bonus IVI drivers!). All my searches have produced vendors that have stopped manufacture (i.e. PXIT.COM)
Thanks for the info. This appears to be a better interface to my system than the Pickering solution as there is a data/address bus available to the users electronics.
However, I don't think there is any NI drivers available.
Well, they have functions that are ANSI C compatible. If you are using LabWindows/CVI, then it will be compatible also. If you are using LabVIEW, then you can use "Call Library Function Node" to call their DLL's. I hope this helps.
