PXI
Can a 6052E card have back and front inputs in PXI-1011 Chassis?
I would like to attach a BNC-2090 input device into the front of a Multifunction 6052E card in my PXI-1011 Chassis. The 6052E card is backside connected with a SCXI 1520 rack. Does the SCXI rack take all function of the 6052E card or can I still use the channels on the front of the card. If so, How do I access those front channels on the card? I have the accessory setting in MAX for the 6052E set to a BNC-2090, but I'm having difficulties locating the signals.
My 6052E card is listed as Device 4, if I put in "access Device 4 and channels 1 & 3 in the VI" should it be able to find those channels without any problems?
(3,056 Views)
Actually, I just need to know if I can aquire data from the SCXI modules and the BNC-2090 at the same time with the 6052E card. If not, is there a single referenced BNC adapter module that can plug into an open SCXI 1520 slot?
Any help would be great!
Marc "the schmig"
(3,046 Views)
The following document has the answer to your question: http://digital.ni.com/public.nsf/websearch/DAF7DADB6FA2481486256A6C00507E0A?OpenDocument
(3,043 Views)
