PXI
CAN program using Channel API receives only 0
Hello everyone,
I'm get in stuck. I'm currently programming CAN interface for a transmission using PXI, Channel API and a .dbc file.
CAN configuration based on .dbc file is downloaded to PXI by MAX.
The problem is that it receives 0 for all the values by Channel API based program (Attached file), though it seems receiving meaningful data when I check raw data by Frame API based program.
Baudrate, CAN port, and .dbc file are correct.
thanks!
Message 1 of 1
(3,267 Views)
