PXI
error calexec 300010
Calibrating PXI4110 Error Measage 300010, what the?
(4,302 Views)
Hello Laerie,
I'm getting the following information about the error:
Possible reason(s):
"Calibration Executive:  Invalid data type in UserField DataType.  Must be 'NUM' or 'STR'."
I would go through the configuration steps and ensure what values you are settingfor your user settings.  Also, can you provide more details when you see the error.  I'd like to try and reproduce it on my end.  Some screenshots of the error and your input settings would be most appreciated.
Paul C.
(4,294 Views)
Hello Laerie,
After doing a bit more searching, I did find some reports of this error with the Agilent 3458A.  Can you confirm what calibrator you're using and which version of calibration executive?
Paul C.
(4,291 Views)
Thank you for your responce, the attached is the message in whole.
Laerie
(4,284 Views)
Hello Laerie,
Can you provide the calibrator / calibration executive version?
Paul C.
(4,280 Views)
Sorry about that!  Agilent 3458A & Fluke 5520A-SC600
(4,263 Views)
Hello all,
This customer has opened a support request with National Instruments.  The issue is being worked on with our R&D group and we will post back the results.
Paul C.
(4,241 Views)
