PXI
Can MXI-4 cables be daisy chained?
I want to connect two 5m MXI-4 cables end to end.  Is that possible and would it degrade signal integrity?
I have a PXI chassis inside a large system and the MXI cable is routed through the system to the PC. there isn't easy access to where the MXI-4 connects to the chassis.  I need to be able to connect to the chassis with a diffenent PC for onsite calibration.  Would I be able to connect a second MXI-4 cable to the exisiting one?
(5,108 Views)
He ReneeT,
No, I'm sorry. The 2 ends of the MXI cable are not the same. You'll need to just buy a longer cable. What length do you need?
(5,092 Views)
Thanks Jeff.  I may be able to get away with the 5m if I unbundle it.  If not, then the 10m will work.  I'll just have to tear it apart and see how much slack I can get now that I know connecting two cables isn't an option.
(4,981 Views)
The part numer for the "MXI-4/MXI Express x1/Reflective Memory Fiber Optic Cable, 10m" is 778959-10. Give us a call at 866-ASK-MY-NI, and we can help get this ordered and shipped for you.
(4,975 Views)
