PXI
Error -88313 occurred at DAQ Assistant
Hi All,
Recently receiving a PXI system (NI PXIe-1071) I'm trying to connect on it through NI MAX. (Ni DAQ MX 14.2)
The PXI system is detected included the two PXI card (PXIe-6345 and PXI-6509).
Neverthless when I try to get information from a channel (AI0 for exemple) on the card PXI-6345 thanks to the test pannel I have an error : error 88313 without any reasons.
Doing the same thing on the card PXI-6509, I can read/write on the ports without any problems,
Thank you in advance for any help you can provide
(5,339 Views)
Hi
It could be a corruption during the installation of DAQmx. you can try to install it again and pay attention to disable the antivirus.
You also can test this board in another slot, for example switching slots between 6509 and 6345.
Paolo_P
Certified TestStand Architect
Certified LabVIEW Architect
National Instruments France
(5,314 Views)
