PXI
Can NI PXI-PCIe 8362 use in PXI 1044 chasing
Currently, we have the system as below:
(a) PXI-1044 chasis
(b) PXI-8106 controller
(c) PXI-5122 DIG
The questions:
(a) can I remotely control this system by using external PC with LabVIEW 8.6 (by passing the embedded controller)?
(b) If not, can I use PXI-PCIe 8362 replace the PXI8106 controller?
Thanks in advance
(3,434 Views)
If you use Real-time module then, you can access remotely.
PXI-8106 can boot real-time OS which is different to Windows OS.
Next,
PXIe-xxxx  controller can not be used with PXI-1042.
Because, PXIe-xxxx  use PCI-express bus lines.
Seyong
National Instruments Korea.
Phone : +82-2-3451-3400
e-mail : supportkorea@ni.com
(3,392 Views)
