PXI
Cannot modify FPGA sampling rate
Hello, I am using a NI PXIe-1071 with a NI 5772 module to sample the signal from an ultrasonic probe with the predefined "FPGA-to-Host.Read" block in LabView. My problem is I cannot reduce the sampling rate from 800MHz to 200MHz to increase the sampling time. Is there any way to reduce the sampling frequency or increase the buffer size to allow a larger sampling period?
Message 1 of 1
(935 Views)
