PXI
PXIe-8880 Trouble Shooting
Hi all,
I've had an PXI system sitting for about a year, I have been practicing with a cRIO instead, (*new LabVIEW user)  Other than booting it up and updating the software and ext. about a year ago on NI MAX, It boot into BIOs just fine. I've never attempted to go passed that until a few days ago.  The PXI will not boot into bios or anything other then the green blinking of Ethernet port. I've read every manual, trouble shooting guide, and NI tech support with a quoted RMA of 3,000. Has anyone else have this problem... The system has never been used in testing nor tampered or damaged... in anyway that I am aware of. I would like to avoid a 3000 bill for a switch or remote start method I am not aware of.
The PXIe is a PXIe-8880 on a PXIe-1078 chassis.
(1,409 Views)
Hi, have you looked at your device in NI MAX? What does it show? An OS? maybe you need to update the firmware or the OS?
(1,328 Views)
