PXI
Cannot set PXI Chassis in MAX
I am trying to set up the chassis and access the inputs/outputs of my PXI6259 card.
I have a PXI 1031 Chassis with 8106 Controller.
I can see the controller and chassis in MAX, I set the controller number but cannot set the chassis type (I get the error Max cannot change the information for this chassis (see pic).
I have checked the bios, it is operating in Labview RT mode.
I can set-up channels in MAX under remote system/ipaddress/devices and instruments/pxi system(PXI 8106)/PXI chassis(unidentified)/INSTR PXI-6259
I have been unable to access from DAQ assistant so far.
Paul
Message Edited by PCroller on 02-27-2008 08:58 AM
(4,081 Views)
Under "PXI System", right click "Chassis" and select "Identify As..." Then you can set the chassis type.
Teri
(4,024 Views)
Hi
This is the problem, I cannot set it, it allows me to select 1031 but then an error comes up saying MAX cannot change it.
Paul
(3,869 Views)
Sorry I can't be of more help. I changed jobs and I do not have a PXI system available at my new place of employment. From what I remember, all the DAQmx stuff has to be set up under the Remote Systems. That's where the actual hardware resides. Someone please correct me if I'm wrong...like I stated, I have no way of looking at it now.
(3,861 Views)
