PXI
Changing PCIe clocking modes (spread spectrum v. fixed freq) for NI PXIe-8106
I don't see in the BIOS any way to change clocking modes for the PCIe interface from spread spectrum to fixed frequency.  Is there another way to do this?
(3,475 Views)
Ken,
You're correct, the BIOS setup utility does not contain an option to enable/disable spread spectrum clocking for the PCIe interface.  On the PXI-8106, spread spectrum clocking is always enabled.  Do you have an application that requires disabling SSC for PCIe?
Eric Gardiner
Senior Software Engineer
(3,470 Views)
