PXI
Chassis PXI-1033: compatibility with MXI4 or PCMCIA host cards
The PXI-1033 Chassis operates with the PCIe 8361 or with the Express Card 8360 host interfaces.
The question is:
Could the PXI-1033 be also connected to the MXI4 interface PCI 8331 or to the PCMCIA cardbus 8310?
Thank you.
N. Roberto
(4,820 Views)
Mr. Roberto,
Thanks for contacting National Instruments. You are correct that the PXI-1033 Integrated Controller and Chassis supports either the PCI Express host (i.e PCIc-8361) or an ExpressCard (i.e. 8360).
Unfortunately, since the PXI-1033 uses an integrated MXI Express, you cannot use any of the MXI-3 or MXI-4 PCI boards. The PCIe and PCI architecture and mapping are different, and the PXI board is expecting a PCIe signal. In general, with MXI express, depending on the setup, you can have PCIe to PXI, or PCIe to PXIe. With MXI express, you cannot have a PCI board in either case.
I have attached below a really helpful utillity to help configure your PXI system including controller, chassis, modules, software, and summary.
http://ohm.ni.com/advisors/pxi
Hopefully you are able to find something that will work for you system, and if you ever have any specific questions about configurations or pricing feel free to contact your local Field Engineer.
Thanks again and let me know if you would like additional explanation,
Jordo
Jordan Randall
National Instruments Italy
(4,807 Views)
Similar question;
I have a PXI-1033 with an Expresscard notebook interface. Now I need to communicate via a stationary PC PIC / PCIe instead. Does this mean that the available options are PCIe-8361 / PCIe-8362 or are there others that will work?
Thanks in advance
(3,775 Views)
