PXI
CompactRIO MTBF
Dear NI,
I can't find the CompactRIO MTBF value.
I just coulf found something like  Bellcore Issue 6, Method 1, Case 3 MIL-HDBK-217F .
Could you please send me the result CompactRIO MTBF value ?
(4,659 Views)
Hello Ricardo,
Can you tell me whether the MTBF number you needed is for a specific module or for the cRIO controller?
Please refer below for cRIO-9004 and cRIO-9002 MTBF numbers
For cRiO-9002
Hours          Temperaure                 Method Used
13,555        40 C, 104 F                   MIL HDBK 217F
95,769        70 C,  158 F                  Bellcore Issue Level II
561,513      25 C , 77 F                    Bellcore Issue Level II
1,618,487   -40 C, -40 F                  Bellcore Issue Level II
For cRIO-9004
500,270      70 C , 158 F                 Bellcore Issue 6
1,253,788   25 C , 77 F                   Bellcore Issue 6
4,314,583   -40 C , -40 F                Bellcore Issue 6
Hope this helps.
Arun V
(4,644 Views)
Is it safe to assume that these MTBF numbers apply to all of the cRio units in particular the 9014 model?
(3,861 Views)
