PXI
Chassis assembly numbers (not catalog order number)
I need the assembly numbers for the following chassis.  This is the part number for the chassis assembly minus all the packaging, literature, etc.
PXIe-1066DC  781812-01
PXIe-1085       781813-01
also which is the correct assembly number for this chassis...
PXI-1045         778645-01           189105K-01 or 189106K-01
Darrow
(6,443 Views)
Hi Darrow,
The part numbers for these devices are as follows:
PXIe-1066DC  152573E-01L
PXIe-1085       153869D-01L
PXIe-1045       189106K-01L
Keep in mind that these are for the latest revisions.  If you own one of these chassis then the part number could be slightly different, but could be found on the device itself.
Josh B
(6,431 Views)
