PXI
Compatability of LabView RT with Third Party( NOT N.I ) PXI chassis
I want to use NI LabView and LabView RT, some PXI chassis of N.I and
some PXI chassis of Third Party( not N.I ) for diversity, How I will Install
Pharlap ETS ( LabView RT ) on those third party PXI's.
More simply
Third party PXI chassis and controllers support LabView RT or not?
Note: Mark Andre Hary mark@SensingSystems.com of Sensing Systems LLC answer to this question as:
"You can't.  I think NI bought Pharlap, and they do not offer board support packages (BSPs) for non-NI PXI controllers.  There is no way to get LabVIEW-RT running on a controller not purchased from NI.  You will have to use a standard RTOS like Linux,VxWorks, or QNX.
Regards
(3,034 Views)
You can install LabVIEW RT ETS on a third party PXI controller just as if it were a PC.  Check the requirements that a PC needs to have in order to run LabVIEW RT ETS.
Check the following link:
http://digital.ni.com/public.nsf/3efedde4322fef19862567740067f3cc/cb3434da94466dd286256e9e006bb775?O...
Ricardo S.
(3,026 Views)
