PXI
Custum SHC1006868 Cable
Does National Instruments make custom cables?  I have the pinout for the SHC1006868 cable and it shows that I will be lossing signals from my 6527 connector because pin numbers 1,2: 24,33 and 23 from the 100 pin connector have multiple lines to the 68 pin connector.
(3,094 Views)
What kind of connectors do you need?  If you look at the PCI-6527 data sheet (http://forums.ni.com/ni/board/message?board.id=270&message.id=1827), it lists recommended cables as SH100-100-F or the R1005050.  These are the cables that you should use with the PCI-6527.
Sean C.
(3,089 Views)
