PXI
Configuration help
Helo everyone,
I need to measure three separate bridges with measuring tape resistance of 100 ohm, connected with a relay multiplexer within the system, 1 Hz.
Can you suggest me which components do I use to configure the system. I'm not exactly sure what to use.
Thank you.
(3,769 Views)
Hello ponorac92,
in this case please do not hesitate co go to ni.com/contact and find there contact information to your local sales. Usually there is also a free of charge phone contact. After explaining your problem, you will be redirected to our technical sales dep., where you will receive support. This is still a really general question, and think, that a support channel with lower Q&A latency is more suitable for solving this problem. This is more suggested, because we offer a large palette of SW and HW that can be used for such and similar task.
B/R
Jozef Lipták
(3,709 Views)
