PXI
Connect eRIO 9149 to PXIe 8840 controller
I am trying to use an ethernet RIO extension chassis with a PXIe 8840 RT controller, and I can not seem to get the two to connect.  I have configured both IPs on the same subnet in MAX, and I can connect individually to them through MAX.  But when I try to use the second ethernet port on the PXIe to connect to the 9149, I get error -63040 "A connection could not be established to the specified remote device."
I have used this chassis before but with a Windows computer, not with a RT Controller.  I tried using a standard Cat 5 cable, a Cat 5 crossover cable (listed in the bottom of the KB page about this subject), and putting a switch in-between the two, and each time I have gotten the same error.
Any Ideas?
(3,371 Views)
Accepted by r_good
This Knowledge Base article gives a good description of what you can do with the second Ethernet port on a Real-Time Controller.
In order to use both Ethernet ports on a dual port controller, you must configure Ethernet Port 2 with a static IP address which resides in a different subnet than Ethernet port 1. Ethernet port 2 can be used to communicate with a private network.
You can also configure the Ethernet Port 2 for EtherCAT communication but you will need to install the EtherCAT driver in your host computer and your RT controller.
You will need to connect the Ethernet port 1 of your PXIe 8840 RT controller, your NI 9149 Ethernet Expansion Chasis and your host computer to the same LAN (using a switch or a router) to configure these target in MAX as well as deploying applications to these targets from LabVIEW instead of connecting the NI 9149 to the Ethernet port 2 of your PXIe 8840 RT controller.
Warm Regards,
Alejandro Balma
(3,337 Views)
Alejandro,
Thank you for the KB, I had over looked the subnet requirements.  After configuring the eRIO and RT eth1 ports to be on a different subnet, the two were able to connect.
Thanks for your help,
Ryan
(3,324 Views)
