PXI
Controller Change slows down the PXIe-1062Q
History: 10 years ago I built a PXIe-1062Q Chassis with a PXIe-8130 Controller running Win-XP. 4 PXI-6542 were installed.
              3 years ago I rebulit a similar system with a PXIe-1082 Chassis, an external Rack mount PC and 4 PXIe-6544 running Win-7
Now:    The XP controller was replaced with an external WIN-7 Rack mount (same type, same OP, same HSDIO 1.7.4., same LabView 2013 programm)
So far, so good, but:
  • A testprogram, loading pattern into the on board memory of the HSDIOs runs on the old XP in about 200ms
  • On the newer system a bit quicker (as expected) but on the rebuilt system it tooks about 2 Seconds (only pattern load, without playing out) .... 😕
Does anybody has an idea what could be the reason for this behaviour?
(1,302 Views)
Maybe for some reason, Win7 system is overloaded in terms of CPU/RAM usage and slowing down the automation?
Is the rack mount PC exactly same in HW specifications?
Santhosh
Soliton Technologies
(1,283 Views)
Hello Santhosh,
yes, the PCs are the same and I changed then with each other -> no effect.
The strange thing I found by changing components was that the PXI-6542 card will go fast when it is mounted in a PXIe-1082 Rack instead of a PXIe-1062Q. But only when the hardware revision of the Backplane is K. In a PXIe-1082 with revision J the PXI-6542 will also work at low speed.
Firmware version of both Racks are the same.
!! When mounted a PXIe-6544 HS-DIO in all sorts of Racks they will work fast as expected. !!
So I found a configuration of both that will work for me, but how can I be sure, that in the future a spare part would also work when it is revision dependent?
(1,263 Views)
Definitely, there is a bandwidth difference 1062 (3GBb/s) and 1082 (8GB/s)
Santhosh
(1,261 Views)
Yes, I know,
but the quicker 1082 (8GB/s)  behaves slower than the 1062 (3GB/s) 😕
and the 1082 rev.J behaves slower than the 1082 rev.K 😕😕
(1,252 Views)
