PXI
Create bootable USB key to format PXI hard drive and boot into RT OS
Hi Waleed,
You are correct.  If you want to use LabVIEW Real-Time, you must first upgrade to LabVIEW 8.5 and then buy the LabVIEW Real-Time Deployment License.
Eric A.
Distributed I/O Product Support Engineer
Message 11 of 15
(3,368 Views)
Dear Eric
I would like to ask about another related issue, the system I have is PXI  8186 controller, and DAQ card 6221 M series with SC 2345 signal conditional.
My application is Active noise control using Real Time operating system for frequencies up to 1500 Hz sampling rate needed 10 000 samples per second.
The question now is Does this DAQ card satisfies my needs?
Best Regards
Waleed
Message 12 of 15
(3,317 Views)
According to the specifications for PCI-6221, this card is capable of sampling rates up to 250 kS/s for analog input and frequencies up to 125 kHz (the maximum sampling rate divided by two).
In the future, you might want to direct your DAQ-related posts to our DAQ discussion forum. Thanks!
Amanda Howard
Americas Services and Support Recruiting Manager
Message 13 of 15
(3,199 Views)
Dear Amanda
My question was for using the PXI 6221 M series, not the PCI one, (for real time application with sampling rate 10 000, max. frequency 1500 Hz and 2 outputs), is this card is sufficient?
Waleed
Message 14 of 15
(3,178 Views)
Hi Waleed,
The specifications for the PXI-6221 are the same, so this hardware should work for your application.
Thanks!
Amanda Howard
Message 15 of 15
(2,783 Views)
