PXI
DAQmx Linux and PXI-2570
I am having problems accessing my PXI-2570 card using the ansi c API for DAQmx on Linux.
Running the switch example that came with DAQmx I get:
$ ./ControlIndividualRelay
Opening relay /Dev1/k0
DAQmx Error: The specified device is not present or is not active in the system. The device may not be installed on this system, may have been unplugged, or may not be installed correctly.
Device:  Dev1
Status Code: -88705
End of program, press Enter key to quit
this led me to use the nilsdev utility which yeilds:
$ ./nilsdev
NI PXI-2570: "Dev1" [Not Present]
NI PXI-6528: "Dev2" [Not Present]
What would cause this to say "Not Present" when I know the board is plugged in?
also, exporting my DAQmx configuration gives:
# ./nidaqmxconfig --export current.ini
Operation successful.
# cat current.ini
 [DAQmx]
MajorVersion = 8
MinorVersion = 0
How could nilsdev detect my cards when my ini file does not have any cards defined?
Why are these cards coming up as not present?
Any help is appreciated.. thanks!
-pclary
(4,078 Views)
Hi pclary
The particular error you are seeing means that the device loader is not running.  Have a look at the following thread.  It has information about starting the loader.
http://forums.ni.com/ni/board/message?board.id=250&message.id=31650&requireLogin=False
Also note that not all distributions of Linux.  Please see the following link.
If you are still having problems, let me know what Linux distribution you are using, and I may be able to provide more help.
Chris_K
(4,065 Views)
Thanks for the help Chris.
Is there a way to check if the loader service is currently running or not?
I am using RedHawk Linux, 2.8.18
-Patrick
Message Edited by pclary on 02-18-2008 03:28 PM
(4,056 Views)
It looks like the devices are not being recognized by your system.
The nidevldu is a library, and not a service so we can't check if it is running, however there are a few other things we can try.
From the terminal run ps -a, you should see the following services:
nimxs
nipalps
nipalsm
nisvcloc
The nipalsm will be running some of the functions from nidevldu.
Also running nilsdev -v -diag will show us the verbose version of nilsdev which might also be helpful.
Hope this helps
Chris_K
(4,026 Views)
