Hello Les Bartel,
Thank you for posting at the discussion forum. The NI CardBus is not configured automatically in MAX. You do need to configure it manually and here is a knowledgebase that explains how to configure it under the PXI System in MAX.
Configuring the NI PXI-CardBus 8310. Please note that you will have to right click on PXI System in MAX and select to delete all identifications before you start configuring the system properly.
Now, from the image that you sent us, it does not seem that any of the cards were installed properly because if they were then we would have at least seen them under Devices and Interfaces >> DAQmx Devices or Traditional NI-DAQ. Please make sure that you have all the drivers installed in your system and that you can find the devices in the device manager.
One thing to note here is the sequence of boot up is important. You need to have the Chassis on before you turn on your computer so that the BIOS of your laptop enumerate the extended PCI bus. Hence, before configuring the Cardbus, make sure that you turn on the chassis first, turn on your computer. Make sure that you properly install the drivers for the cards you have in the chassis (you should get a found new hardware wizard upon boot up to windows). IF you have installed the devices, then you could proceed to configure the cardbus.
To get to device manager, right click on my computer >> properties >> Hardware tab >> Device Manager. You should find a section that says National Instruments Devices and it should list all of the cards you have in the chassis.
Please let me know if you still have problems configuring your system.
Best Regards,
Ayman Kabire
