PXI
DAQmx on recent Linux system
I use DAQmx on Linux. I am now moving from SL6 to a newer distribution for my new computers. I struggle to get DAQmx to install.
If I try to install DAQmx straight, I get the following message:
Checking required install tools...
Checking installer tool versions...
dpkg       Not found in current path
rpm        4.11.3 can be used with a default installation path
tar        1.28
Checking dependencies...
glibc      2.19
Unpacking install files to /tmp/nidaqmx-8.0.2f0.install...
*********************************** ERROR ************************************
*       ERROR: 3.16 kernels are not supported!          *
*    Running a 2.6.x kernel is required to continue this installation.       *
Installer is aborted.
Now, I understand that NI-KAL has to be installed first. So, I get it from the latest NI-VISA. NI-VISA 15 installs fine. But now, when I try to install DAQmx, I get this:
Installing NI-DAQmx for Linux Installer Distribution version 8.0.2f0...
Pre Installation .
Post Installation .
Skipping nikali-2.1.0-f0.noarch.rpm installation, same or newer already installed.
Skipping nipalki-2.6.3-f0.i386.rpm installation, same or newer already installed.
Skipping nipali-2.6.3-f0.i386.rpm installation, same or newer already installed.
Skipping nidimi-1.9.0-f0.i386.rpm installation, same or newer already installed.
Skipping nimdbgi-1.3.1-f0.i386.rpm installation, same or newer already installed.
Skipping nimxdfi-1.4.1-f1.i386.rpm installation, same or newer already installed.
Skipping niorbi-1.9.0-f0.i386.rpm installation, same or newer already installed.
Skipping nipxirmi-1.6.0-f0.i386.rpm installation, same or newer already installed.
Pre Installation ...............................
Preparing...                          ################################# [100%]
	file /usr/local/natinst from install of niscarabmm-1.2.1-f0.i386 conflicts with file from package nikali-15.0.0-f1.noarch
	file /usr/local/natinst from install of niscarabmm-1.2.1-f0.i386 conflicts with file from package nipalki-15.0.0-f0.i386
	file /usr/local/natinst from install of niscarabmm-1.2.1-f0.i386 conflicts with file from package nispyi-2.8.1-f0.i386
	file /usr/local/natinst from install of niscarabmm-1.2.1-f0.i386 conflicts with file from package nipalerri-15.0.0-f0.noarch
	file /usr/local/natinst from install of niscarabmm-1.2.1-f0.i386 conflicts with file from package nipali-15.0.0-f0.i386
	file /usr/local/natinst from install of niscarabmm-1.2.1-f0.i386 conflicts with file from package niorberri-14.1.1-f0.noarch
	file /usr/local/natinst from install of niscarabmm-1.2.1-f0.i386 conflicts with file from package niorbki-14.1.1-f0.i386
	file /usr/local/natinst from install of niscarabmm-1.2.1-f0.i386 conflicts with file from package niorbi-14.1.1-f0.i386
	file /usr/local/natinst from install of niscarabmm-1.2.1-f0.i386 conflicts with file from package nimdbgerri-14.2.1-f0.noarch
	file /usr/local/natinst from install of niscarabmm-1.2.1-f0.i386 conflicts with file from package nimdbgki-14.2.1-f0.i386
	file /usr/local/natinst from install of niscarabmm-1.2.1-f0.i386 conflicts with file from package nimdbgi-14.2.1-f0.i386
	file /usr/local/natinst from install of niscarabmm-1.2.1-f0.i386 conflicts with file from package nimxdferri-14.2.1-f0.noarch
	file /usr/local/natinst from install of niscarabmm-1.2.1-f0.i386 conflicts with file from package nimxdfki-14.2.1-f0.i386
	file /usr/local/natinst from install of niscarabmm-1.2.1-f0.i386 conflicts with file from package nimxdfi-14.2.1-f0.i386
	file /usr/local/natinst from install of niscarabmm-1.2.1-f0.i386 conflicts with file from package nidimerri-14.2.0-f0.noarch
	file /usr/local/natinst from install of niscarabmm-1.2.1-f0.i386 conflicts with file from package nidimki-14.2.0-f0.i386
	file /usr/local/natinst from install of niscarabmm-1.2.1-f0.i386 conflicts with file from package nidimi-14.2.0-f0.i386
	file /usr/local/natinst from install of niscarabmm-1.2.1-f0.i386 conflicts with file from package nipxipfki-15.0.0-f0.i386
	file /usr/local/natinst from install of niscarabmm-1.2.1-f0.i386 conflicts with file from package nimdnsresponder-14.0.0-f0.i386
	file /usr/local/natinst from install of niscarabmm-1.2.1-f0.i386 conflicts with file from package niapalerri-15.0.0-f0.noarch
	file /usr/local/natinst from install of niscarabmm-1.2.1-f0.i386 conflicts with file from package nipxipfi-15.0.0-f0.i386
	file /usr/local/natinst from install of niscarabmm-1.2.1-f0.i386 conflicts with file from package nipxirmi-2.8.0-f0.i386
file /usr/local/natinst from install of nidaqmxcapii-1.6.1-f0.i386 conflicts with file from package niapalerri-15.0.0-f0.noarch file /usr/local/natinst from install of nidaqmxcapii-1.6.1-f0.i386 conflicts with file from package nipxipfi-15.0.0-f0.i386 file /usr/local/natinst from install of nidaqmxcapii-1.6.1-f0.i386 conflicts with file from package nipxirmi-2.8.0-f0.i386 file /usr/local/natinst from install of nidaqmxcapii-1.6.1-f0.i386 conflicts with file from package niiotracei-15.0.0-f0.i386 Error installing NI-DAQmx for Linux Installer Distribution 8.0.2f0. Installer is aborted.
Is there any workaroung ?
Or is NI planning on updating the DAQmx installer, so that it is properly packaged with respect to the newer libraries ?
Thank you for your help,
(5,228 Views)
Hi jsalort,
 What distribution Linux do you use ? SL7 or SL6 ?
If you use SL7, it's not supported.
Eloise
NI France
(5,113 Views)
Hi Eloise,
Thank you for your reply. I am using 32-bits OpenSUSE 12.3.
Julien
(5,107 Views)
Hi Julien,
Could you try to install DAQmx Base 14.0 (unless I am mistaken you try to install version 8.0.2 which does not support OPEN SUSE 12.3)
https://www.ni.com/en/support/downloads/drivers/download.ni-daqmx-base.html#326056
Eloise
NI France
(5,077 Views)
Indeed, DAQmx Base 14.0 installs fine. I don't know if my hardware will be supported with DAQmx Base though.
Is NI planning to update the DAQmx install package ?
Thank you
(5,070 Views)
