PXI
SH1006868 cable: How does the 100 pin plug map out to the two 68 pin plug?
Concerning the SH1006868 cable:  How does the 100 pin connector map out to the two 68 pin connectors?  What are the exact pinouts of each connector?
(4,289 Views)
Lockheed,
Attached is an excel spreadsheet which contains the info you asked for.
Have a good day,
Lorne Hengst
Application Engineer
(4,276 Views)
It took me a really long to find this information. Is there any reason why this is not publised under the datahsheet of the cable, just like the SH100100 or other similar cables?. I spend a lot of time reading through datasheets and tryign to figure out the pinout myself. I think this will save a lot of issues to a anyone trying to use this cable.
(3,115 Views)
