10-29-2015 03:28 PM - edited 10-29-2015 03:31 PM
Hello all,
Im using a PXIe-8135 running windows 7 and LabVIEW 2015. I have a DECS 250 AVR connected to it via ethernet cable and am able to ping my devices IPaddress. However the device cannot be connected through NI MAX. I have tried the wizard in NI MAX to add TCP/IP address as well as manually entered information, with no luck. I am very inexperienced in networking so bear with me. Thank you for your time and help with this matter
Best,
John
10-30-2015
04:59 PM
- last edited on
01-09-2025
01:31 PM
by
Content Cleaner
10-31-2015 01:37 PM
Thanks for the response.
i am using NI VISA 15.0, and the device is directly connected through ethernet cable. I have tried the first link numerous times and through all the different options. However, I noticed the subnets are off.
the PXI subnet is 255.255.254.0
and the AVR is 255.255.255.0
Could this be the issue?
thanks,
John
10-31-2015 09:28 PM
