PXI
DSTAR-B missing in Linux Driver for NI-6674T
Hi there,
  I'm trying to control the timing module NI-6674T through a linux program. There is a linux driver available in NI Github space (https://github.com/ni/ni6674t) but it does not seem to have implemented DSTAR-B lines.
I checked the ni6674t_registers.h where the register map for input and output lines are defined and DTAR-B is totally missing (although entries for DSTAR-A exisit).
I was wondering if there is a version of this driver which supports triggering through DSTAR-B? Otherwise, would it be possible to know the register map so that we could improve the driver and include DSTAR-B?
(1,041 Views)
That driver on Github is pretty old. NI actually has newer Linux drivers that we're hosting on our site. With the newer NI-Sync driver, you should be able to access and route DStarB.
https://www.ni.com/en-us/support/downloads/drivers/download.ni-linux-device-drivers.html#350003
These are now repository add-ons. Here are the instructions for the installation:
https://www.ni.com/en-us/support/documentation/supplemental/18/downloading-and-installing-ni-driver-...
*Make sure to remove any NI drivers that predate version 18.0 before install these.*
Here's the readme for the newest NI-Sync Linux driver. Please pay attention to the support OS section.
https://download.ni.com/ni-linux-desktop/2020.07/readme/drivers/readme_NI-Sync
Lastly, here are a couple overview documents about what's support between the 6674T and NI-Sync on a Linux OS.
https://www.ni.com/en-us/support/documentation/supplemental/19/ni-sync-limitations-on-linux-desktop-...
https://www.ni.com/en-us/support/documentation/supplemental/18/pxie-6674t-trigger-routing-in-linux-d...
(1,001 Views)
