PXI
PXI-8106 2.0GHz Model Controllers
I have two PXI-8106 controllers with a 2.0GHz Intel T2500 Dual Core Processor built in instead of the usual 2.16GHz processor. The part number is 196896B-712. There are no serial numbers on the controllers. Are these custom models, or should they be treated the same as the 2.16GHz controllers?
(1,418 Views)
Are you sure it is a PXI-8106?
Based on the user manual, 8106 comes with Core2Duo T7400, not a Core Duo T2500.
It is still possible that it was a custom variation or an early release.
Santhosh
Soliton Technologies
(1,395 Views)
Hello. Both of the controllers I have were tested and confirmed as having the 2.0 GHz processor instead of the standard 2.16 GHz.
(1,371 Views)
