PXI
Differences between NI PXI controller and NI FP-1000
What is major differences between PXI Controller and FP-100???
Rd,
Ganesan
(5,385 Views)
Hello CPUT,
The FP-1000 is a network interface module for the FieldPoint I/O system that is scheduled for obsolescence and was last available for purchase on July 1, 2011. FP-1000 connects up to nine Field Point I/O modules through either a RS232 or RS485 network. The PXI system is a PC based platform that utilizes a PCI bus.The PXI system can be used as a Windows based system or run as a Real Time Target. This knowledge base has an extensive explanation of the PXI chassis, controller, and modules.
Wear
Product Support Engineer
(5,358 Views)
Thanks ,
What is the sampling rate of FP-1000 device ?
Kind regards,
Ganesan
(5,351 Views)
Hello CPUT,
This [broken link removed] knowledgebase talks about the sampling speed of the Field Point Modules in detail.
Wear
(5,337 Views)
