PXI
Dividing FPGA labview
Hi  for all,
my problem look easy but its not real.
 i want to introduce simple equation to my project which simply generate PWM signal with "PWM bridge pair" function. as this function need Ontime and Half_period  with format (I16) and (I32) i want to introduce simple function which convert frequency 32kHz to 625 ticks = Half_period(I32) since FPGA clock its 40MHz so i tried to introduce this equation
Hal_period (PWM pair bridge Block) = (40000 / F) / 2 in order to obtain F like input in kHz and not ticks as input.
 i found in forum many solutions like :
https://forums.ni.com/t5/Example-Code/LabVIEW-FPGA-Scaling-and-Division/ta-p/3996338
or this one also
https://forums.ni.com/t5/LabVIEW/Dividing-in-FPGA/m-p/189324/highlight/true#M109575
 i download it  which in attached piece 2   but how to use it with my existing project.
i do like this my programme is attached in piece 1 with comments  but not fuction   :/.
thanks for all helps.
Message 1 of 11
(6,541 Views)
No answer !!!!!!!!! Please i need help .
i'am blocked at this problem 😕
Message 2 of 11
(6,504 Views)
Rayden,
Could you clarify what exactly is not working for you? You say your program does not function but it is hard to identify what your problem actually is.
I did notice that in the code you posted, you have a single cycle timed loop warpped around your entire program. The single cycle timed looped is mean to contain a small amount of simple code. In your program, you have a lot going on inside your single cycle timed loop. I would recommend using a regular while loop instead.
Message 3 of 11
(6,487 Views)
I want simply to divide 4000 by variable I32 . it means i want to convert ticks in frequency as FPGA clock is 40MHz
F (KHz) = 4000 / Variable (tikcks) thats it. the problem is dividing when i use R and Q fraction or simply bloc  fraction /   is not function in labview with FPGA target.
Message 4 of 11
(6,459 Views)
Comparing your code to the provided example, it seems like you are missing a shift register in your while loop. Could this be the cause of your error?
Again, I would not recommend using a single cycle timed loop with a while loop inside of it.
Message 5 of 11
(6,443 Views)
not yet. 😕
the problem is how to inject while loop and FPGA Horloge loop.
there is no other solution without looping to avoid loop problem to do dividing of 2 variables in FPGA !?
Message 6 of 11
(6,312 Views)
You cannot divide or use loops inside a single cycle timed loop.
Message 7 of 11
(6,294 Views)
Yes i confirm it.  So how can i do to divide 2 variables format U16 ?!!
Please i am blocked for 3 weeks 😕
Message 8 of 11
(6,287 Views)
You should be able to divide two U16s in a normal while loop. Just make sure to remove your single single timed loop. Division takes more than one cycle of a timed loop.
Message 9 of 11
(6,274 Views)
i didn't understand can you give me some détails !
dividing in labview its different than dividing in labview FPGA  😕
please can you tell me what modification i must introduce to my program a sugestion look very usefull. thanks
Message 10 of 11
(6,265 Views)
