PXI
Dll not found
We are trying to load a VI with a link to a dll but keep getting the error:
"Failed to load shared libarary SRCPW.dll:ZeroReturn:D on RT target device"
We have ensured that the filename conforms to the 8.3 dos format. Also, the dll resides in the same directory on the PXI drive and on the host computer.
Any help will be appreciated.
Sam
(3,204 Views)
Sam,
Are you calling other DLLs within the dll that is failing to download? That will definitely cause problems. Also, you may be experiencing these issues due to accessing some of the Win API that is not supported by the RT OS. Hope that helps.
Dr. RT Jr.
(3,204 Views)
